Front loader error code f06 and eo3
What are these error codes and how can I fix it
Questa è una buona domanda?
@jvanselow E03 F06 typiocal means your washer has an interface communication error. The main control board isn't communicating with the front interface control board. Check to make sure that all the cables between the two boards are connected and secure. It will help if you can tell us what model your washer is so that we can get more information about these errors for you.
wfw94hexw2 duet washer model, I have replaced the main control mother board,the interface and STILL F06 and E06 instantly when press start, Theres NO wiring issues or corrosion . All are plugged in firmly, Theres no real answers other than repetitive ones, Everyone say the same thing “check the wiring” check the wiring, well im done with all that after 3 weeks. Just keep buying parts , eventually ill get it i guess, Who needs food or gas? only the poor people like me thats who, Thanks < frustrated
Correction. F06 E03
Did you manage to fix it? I have the same error. Replace the CCU but no changes.
Most likely the front panel going out due to moisture. You can bake the front panel circuit board in your oven at 150 degrees for 15 minutes to drive it out, but it will eventually come right back again. My current work around is to enter diagnostics mode by pressing 3 random buttons, 3 times until all the lights turn on. Exit by pressing the power button twice. Then start it normally. This appears to be a common problem with all Maytag and Whirlpool machines. Highly suggest people stop buying this brand!
My basement got flooded and the machine has these errors. I am glad to find some possible attempts before contacting repair.
Parti & Attrezzi Popolari
Acquista tuttiI perused several websites looking for a solution to the F06 E03 error code and in many cases only found, "....interface communication error....main control board isn't communicating with the front interface control board." The solution, if given is to check the wire connections. Not terribly helpful. One site suggested that I should check to see if the pump is plugged, before checking any wiring and control boards, because it is easier. It is not, but I did it anyway. When I disconnected the inlet to the pump (easy!!!) I found lint, wood screws, collar tabs, paper clips, 27 cents in change, numerous pieces of candy wrapper, other stuff, and....drum roll....a cotton face mask used during the height of the pandemic. That is, it was plugged solid. Put it all back together and our WFW94HEXW2 duet washer is as good as new. Total cost of repair: $0.00.
Did the random button push now cods are gone but pump is running without the tub moving
codes are gone tub won’t move, done want to burn up anything. Tub motor moves freely so I guess that motor is fine
Ultime 24 Ore: 6
Ultimi 7 Giorni: 38
Ultimi 30 Giorni: 181
Tutti i Tempi: 18,499
