Salta al contenuto principale
Modello A1419 / EMC 3070 / Metà 2017 / processori Core i5 3.4, 3.5 o 3.8 GHz o Core i7 Kaby Lake 4.2 GHz (id ImAC18,3) / Retina 5k display. Fai riferimento alle guide del modello più vecchio dell'iMac 27" Retina 5K display (fine 2014 & 2015), dato che il sistema è molto simile.
Is the stand removable?
Is the base/stand/foot removable like in older model iMacs? Is a vesa mount possible without direct order from apple?
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Sorry, you'll want to get the VESA mount model.
So far none of the 'Thin Series' offer a user removable foot. The iMac Pro slideware at WWDC implied it will offer a removable foot. But we'll need to wait to see if it ends up being true.
Update (11/21/2021)
The only way to get a VESA mount 27” iMac is to order it explicitly, you can’t really alter things later.
The complete system needs to be taken apart to replace the foot stand and you need quite a few parts.
Punteggio 1
Parti & Attrezzi Popolari
Acquista tutti
https://www.youtube.com/watch?v=WFSyl9_9...
Punteggio -1
2 Commenti:
Sorry guy this was true with the 2011 iMac and the displays. With the 2012 models and newer Apple altered the design preventing the use of the Apple VESA kit.
Only with the intro of the iMac Pro did Apple re-introduce the older design for the foot assembly. So only that model has a removable foot without taking the system fully apart.
da
Yes, but this is a site dedicated to taking these things apart. There are already guides for servicing all kinds of things Apple hasn’t made convenient. If there were anywhere that could put a guide together to remove this inconvenient foot, this is the place.
da
Aggiungi la tua risposta
Augustus Cross Mackenzie sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 22
Tutti i Tempi: 10,220
