Salta al contenuto principale
L'aggiornamento di Marzo 2015 della linea 13" dei Macbook Pro con Retina Display (modello A1502) adotta processori Intel Core i5 ed i7 di quinta generazione, introduce inoltre il trackpad Force Touch.
Will a M.2 SSD work in my MacBook Pro?
Will the M.2 version of the Samsung 850 EVO work in the MacBook pro early 2015 with an adaptor for the proprietary connector?
I mean, can the MacBook Pro early 2015 boot from a SSD drive?
Update (06/21/2017)
I forgot to comment about the OWC option. They are meant to be compatible and work perfectly on a Macbook. However, as far as I know they are not OPAL compliant in order to encrypt the ssd.
Questa è una buona domanda?
Punteggio 2
1 Commento
Here's a good write-up on OPAL: The Pros and Cons of Opal Compliant Drives
Apple currently offers self-encrypting drives (SED) as well as folders within the OS natively via FileVault services. Use FileVault to encrypt the startup disk on your Mac. I might add High Sierra will be doing this natively with the new APFS. Heres a bit more: Wikipedia - Apple File System APFS
As far as OWC Aura SSD support for FileVault here is what they say: OWC Enclosures, Drive Docks, & SSDs: FileVault and BitLocker Support (2017)
We don't use Apple's FileVault services or any other full drive encryption service as its too hard to recover data. Instead we use encryption keys (USB) and discreet file/folder encryption.
da
Aggiungi un commento
7 Risposte
Soluzione Prescelta
Apple uses a PCIe x2 SSD using NVMe. The Samsung 850 EVO is a M.2 SATA SSD drive and will not work in a Mac NVMe based system.
You would need a Samsung 960 EVO which offers the needed NVMe interface. But, we still have a problem! As Apple's NVMe OS driver only supports their SSD.
Now the rub! In the Beta copy of MacOS High Sierra people have reported the new NVMe driver now allows 3rd party NVMe drives to work!
I my self have not tested this and Apple could pull support in the final released version of High Sierra so I wouldn't tempt fate here until the OS is officially released this fall. Lets see if the support is still present then.
Here's a good chart explaining the architecture of SATA Express & M.2
Confused! It's a mess! SATA Express was stillborn while you'll find logic boards with it very few drives offer it. M.2 is a different interface but leveraged the same architecture of SATAe just in a different connector.
IEEE did a better job within Ethernet's different PHY's. While it makes sense to have a common physical interface (M.2) and then use keys to define what the interface can support (device wise). This scheme is a failure! As the hardware & OS folks don't abide by the rules and oddball makers of adapters have confused things even more.
Punteggio 6
8 Commenti:
Mmm... As far as I know the macbook pro early 2015 brings an ssd which is PCIe as you have just correctly said, but it is AHCI rather than NVMe. So no NVMe ssd disk has been proven to work on this system. It is true that the High Sierra beta is able to recognize NVMe out of the box but what is not clear enough is if the macbook can boot from it. That is why I was asking if the 850 evo would work, since it is SATA and I do not know if this macbook can boot from an internal SATA drive.
da
Ah... if it where so simple! ;-{
Reference: MacBook Pro 13" 3.1 GHz i7 (Early 2015) "Proprietary* (PCIe 2.0 x4)" and the MacBook Pro 13" 2.8 GHz i7 (Late 2013) was the first with a PCIe "Proprietary* (PCIe 2.0 x2)" The older MacBook Pro 13" 3.0 GHz i7 (Early 2013) Which used SATA (AHCI) "Proprietary* (6 Gb/s)"
da
The problem here is Apple has altered the design of their systems enough that some will work and others not using the M.2 adapter running with the SATA (AHCI) SSD's.
We ran three different series and found only the older SATA based system was reliable using an adapter with an M.2 SSD. We did note the 2013/14 PCIe x2 models did work with the same SSD but if was not reliable when stressed. It might be an issue with the quality of the adapter which also has a bearing here as well.
I would focus on using the OWC drives as they have done the QC on their product than trying to get these adapters with an M.2 drive to work.
da
Oh! Thank you for such high valuable information. So from your answers I can guess that a sata m.2 drive will work on the MacBook Pro 13" 3.1 GHz i7 (Early 2015) along with the adaptor even for booting, but it will not be reliable. Since it seems you have made several experiments, have you tried to boot MAC OS high sierra beta from an NVMe drive in the MacBook Pro 13" 3.1 GHz i7 (Early 2015) or in any that could give us some information.
da
At the time of our testing we where using Yosemite and also tried using a beta of Sierra. We have not revisited using M.2 drives as we decided to stick with Apple & OWC drives because of our testing. We don't see M.2 NVMe SSD's to be any different and more likely worse as there timing is even tighter (review the M.2 specs).
As far as High Sierra it offers by default a new low level file system (APFS). So things could get worse here. If I do any testing it will be with the last candidate or the finial version when it comes out this fall.
da
Mostra altri 3 commenti
@oldturkey03 we are going to see a lot more of this question on different Macs so I changed the title to be more inclusive. Now I've lost the ability to move the former comments down to this answer. Seems like this change was made without really asking us @kaykay and I'm not a happy camper to lose that option. what am I supposed to do with "me too" answers now? These changes were made after the staff listened to a 14 year old and the change reflects that wisdom. How do I move the comments from above to this answer?
Punteggio 2
8 Commenti:
@mayer I hope I moved the right comment. We could never move a comment from one area to the next. The only way to do it is by making it an answer, then converting it to a comment to another answer. Is that the right comment that I moved?
da
@mayer luckily I've not had that issue. Like I said I go from comment to answer then to comment at proper answer. Somewhat cumbersome but it worked for me thus far....
da
@mayer no one informed me of any changes to the site, this might be a bug?
da
@kaykay Go to a "me too" answer and see what options you would like me to use.
da
The simple answer is “NO. It doesn’t work.” However, when you take a lot of things into context, the answer becomes a bit blurrier and we get to see the technical aspects of the entire question.
Let’s start by saying that Apple uses their own PCIe interface which is often an 2 lane PCIe port, especially for older MacBook Pro’s. Not only is it outdated but it also comes with its own SSD and the drivers that the Mac computer runs often are only compatible with that SSD and nothing else.
However, it’s been often rumored that the latest High Sierra updates have actually offered a PCIe/NVMe interface update that can actually accept third party PCIe/NVMe drives.
This really hasn’t been confirmed by many people in the scene, however. So this is a thread that we have to approach carefully.
Are NVMe PCIe M.2 Drives Compatiable with Macs?
Punteggio 1
5 Commenti:
Has any more progess been made on this? The M.2 NVMe are way cheaper than OWC. If they would work with High Sierra and an adapter, it would be the way to go.
Please let me know if this has been tested, or I might have to be the guinea pig.
da
How about reviewing your choices here: The Ultimate Guide to Apple’s Proprietary SSDs.
da
I am waiting for this too
da
Hopefully with latest stable High Sierra updates its a way to go. I own a MBP mid-2015 A1398 which has support for Nvme
da
Yes it works.
Here is my setup on my MBP late 2013
1.Samsung MZ-V7E250BW 970 EVO Interne SSD 250 GB NVMe M.2
2.JSER SSD-Konverter, konvertiert 12- und 16-polige 2014/2015-Macbook-SSD auf M.2-NGFF-M-key-SSD, für A1493, A1502, A1465, A1466
Everything you need is OSX High Sierra. After you installed OS on your new SSD you can also upgrade to newest OS
da
I am currently in the process of installing MAC OS Mojave with help of an adapter on a 512GB Intel SSD 6.
I tried the Inland 512GB (The high speed one) before this, it worked (not really), sometimes my laptop just failed to boot and was running a bit slow.
Will update after a few days how this settles.
I have an early 2014 Macbook Air model: A1466.
I used the adapter below:
https://www.ebay.com/itm/1x-PCI-E-x4-M-2...
Punteggio 1
1 Commento:
Yes it works. I would say the computer has been reliable and stable.
The boot up time has slowed down but it's been working just fine.
da
I have an early 2015 13” Macbook Air, I got me an adapter and a Crucial P1 1TB 3D NAND NVMe PCIe M.2 SSD - CT1000P1SSD8, this one did work after I got correct adapter.
Punteggio 0
2 Commenti:
So it did work with the correct adapter that you had? just wanting to confirm
da
yes, it works very well, and the speed is quite good, but the disk speed dropped considerably when my computer got the new APFS file system but even still it is quite fast.
da
Disk utility is not detecting my SSD.. bought a 512GB Intel SSD 6 and Im using an adapter.
Any useful tip to solve this problem?
Punteggio 0
1 Commento:
Near the coloured buttons on the top left of Disk Utility is a drop down menu, make sure you've got 'Show all devices' selected. If you have 'Volumes' selected your new SSD will NOT show up as there is, as yet, no volume to show.
Once you see it, you can format it and install the OS.
da
Near the coloured buttons on the top left of Disk Utility is a drop down menu (View), make sure you've got 'Show all devices' selected. If you have 'Volumes' selected your new SSD will NOT show up as there is, as yet, no volume to show.
Punteggio 0
1 Commento:
Hi Brian, will try it. Thanks for the help!
da
Aggiungi la tua risposta
[deleted] sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 27
Tutti i Tempi: 74,325
