Salta al contenuto principale
Repair and disassembly guides for the Compaq Presario CQ60.
Compaq Presario CQ60 black screen issue
Hi,
I have a problem ... laptop screen is blinking and cut the picture frequently ...then I restarted the laptop...works fine but the fan spinning very fast and causes heat also...then after 3 days it suddenly shutdownn while i am surfing net...I started the laptop 2-3times power is on but SCREEN IS BLACK...why what is the issue....and I have cleaned the fan still it blows hot air why?... Please give me solution....please...soon as possible...
Questa è una buona domanda?
Punteggio 1
1 Commento
Hello ,
Please give me solutions...
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Are the slots where fresh air is entering the computer clean? The symptoms are that those of the CPU or GPU are getting to hot and the PC is shutting down.
Punteggio 1
1 Commento:
Hi,
Problem with laptop issue is solved, mechanic had replaced the damaged graphic card and finally laptop works fine again... Thanks.
da
Aggiungi la tua risposta
Shakti sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,205
