Salta al contenuto principale
The Dyson V6 Motorhead Vacuum is a lightweight, cordless vacuum. It easily converts for handheld cleaning using a simple dirt bin instead of replaceable trash bags.
Why is my Dyson not working?
my Dyson inst working and i have no clue why? how much would it cost to be looked at and fixed and who can i take that to?
Questa è una buona domanda?
Punteggio 1
2 Commenti
Please give us a description of its symptoms. What will it do and won't do.
da
only a year old-used maybe 10times-suction for 2 times , then I went back to using my $50 Shark-was going to throw it out then saw it was guaranteed for 2 yrs. Purchased 5/14/16 Where can I take it for repair? Most expensive vac I've ever had & never worked well.Tried my neighbor's first & his is old & still works fine. TY
da
Aggiungi un commento
4 Risposte
Risposta Più Utile
I would first suspect a bad battery. When you put it on the charger, does the light(s) glow? If you have access to another battery, try it. If that fails, the power button or wires to the battery have broke or failed. Use the below guide to check that out.
Dyson V6 Motorhead Motor Replacement
Punteggio 3
Just tell me where I can get it repaired? My cheap Shark is almost 3 yrs old & works fine.
Punteggio 0
email answer to Granniejude@aol.com
Punteggio 0
My vacuum it works for a short period of time and stop. How can I fix it?
Punteggio 0
Aggiungi la tua risposta
taylah woollard sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 2,823
