Salta al contenuto principale
The first generation of the Chevrolet Aveo, identifiable by the internal code T200, the T250 being a facelifted model. This vehicle is also sold as a Pontiac G3, Daewoo Kalos or Pontiac Wave.
How to replace the AC condenser?
I went ahead and refilled the freeze on gas on the low pressure end of the vehicle refill pipe. A man told me to relieve the pressure from the high pressure end and continued to fill with freeze on on the low pressure end. The condenser turns on but no cold air comes out.
How do I change the condenser in this vehicle since it does not seem to be working ?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@jason5887, Jason, I take it you mean AC compressor. I will post proper charging procedure in a link below. Before changing anything your problem could be a leak in the AC system/bad relay/fuse/plug/wire/switch/etc. and should be checked for this, trouble shooting/repair links below may help solve your AC's issue.. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.aa1car.com/library/ac98.htm
https://www.youtube.com/watch?v=pCv7rCdc...
https://www.youtube.com/watch?v=_Peb9o-L...
https://www.youtube.com/watch?v=Pdq8JAlc...
https://www.youtube.com/watch?v=w17DpGCc...
Punteggio 3
1 Commento:
Thank you so much I will go though these trouble shooting procedures and hopefully these solve the issue regarding the compressor.
da
Aggiungi la tua risposta
Jason Mendez sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 28
Tutti i Tempi: 2,802
