Salta al contenuto principale
Fourth generation of the Toyota Pickup.
Wont idle when warm
Truck has a 22r. it runs fine until warm then it wont idle.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
@lvec1 , Lou Vecchia, Possibly a stuck EGR valve or vacuum leak, although there are a lot of things that could cause idle problems, dirty carb., weak fuel pump, clogged filter, bad plugs, failing coil, etc. etc.. Links below may help trouble shoot your issue.
http://www.toyotanation.com/forum/80-89-...
http://4x4wire.com/forums/ubbthreads.php...
Punteggio 2
1 Commento:
Ok Thanks. ill check the links.Going to work on it on Thursday.Ill post what i found. I have replaced the carb and checked for vacuum leaks.
da
my 2003 toyota truck will run but will not idle and dies
Punteggio 0
1 Commento:
new gas tank and fuel pump and new idle senor. new fuel filter
da
Aggiungi la tua risposta
Lou Vecchia sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,895
