Salta al contenuto principale
AC power adapter for MacBook, MacBook Pro, and MacBook Air. Uses a self-aligning magnetic connector that disconnects safely when tugged. First-generation (2006-2012) MagSafe chargers have a slightly thicker, L-shaped connector. Available in 45 W, 60 W, and 85 W versions.
How to repair the wire from the box charger
My animals always seem to find the small cord great for chewing, and I've bought 3 of them so far. Well this last one they chewed next to the square charger part, and thank god left enough room for us to temporary splice the wires together. Is there a way to open up the square charger part and make the wire repair in side of that?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Risposta Più Utile
These units were not built to be opened. Your best bet is to solder the splice and spray your cords with Bitter Apple, found here: http://www.petsmart.com/product/index.js...
Punteggio 3
Parti e strumenti correlati
I am the proud owner of a 10lbs rabbit, which is to say I have the exact same problem. This time bunny did my girlfriend's macbook charger right at the base of the cord, the hardest spot to repair. I knew I was going to have to crack open the adapter block, but a cursory inspection reveals that Apple fuses the plastic casing quite robustly in lieu of screws or fasteners. Gah!
So, after experimenting with several other techniques recommended on other sites. (One of these involved a mallet and a flathead screwdriver, and it apparently woke my neighbor up at 2AM...Sorry, dude. Will have to leave a note.)
Anyway that's when a better idea dawned on me. I was trying to slowly slice through the plastic seam that keeps the powerblock sealed with a box cutter and a fresh razor. This wasn't working very well. But, I DO have a gas stove in the kitchen. After heating the edge of the razor blade to discoloration, it will slice right through the seam for about 4 seconds before you have to reapply heat. No need to worry about cutting through internal connections, because the internals are heavily shielded all around with a copper heat barrier. Just work slowly. The neater the cut, the cleaner it will look after you reassemble.
When the seam starts to give under light pressure, pry the block open gently to break the glue bonding. Try not to lose any of the small plastic or stainless pieces that form the cord-keeper assembly.
Then you can slice off the rubber grommet, retaining as much of the grey and black wires as possible. These will protrude through the hole in the power block after the repair job. Strip and solder. You'll notice the AC cord is coaxial. strip back enough of the shield (ground) to get a good connection. On mine, grey goes to the inner wire. Black is ground. Tin all four lead ends with solder, then fuse together with the iron. Wrap electrical tape or use liquid electrical tape if you have it to keep the wires from shorting. Use your favorite glue or tape to refasten the plastic case.
Spend the $60 you just saved on a good fire extinguisher, you warranty-voiding rebel, you.
PS- With a bit of care it is possible to make this look like a decent repair job. My girlfriend's charger happens to look like a bag of smashed *^^. But You will have the benefit of my experiments-gone-wrong.
Cheers.
Punteggio 3
Aggiungi la tua risposta
Emilia sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 6,672
