Salta al contenuto principale
Lanciato da Samsung a marzo 2016. Modello SM-G930.
error code 410 on android 7.0 update
I have tried many times to update i am on a rooted samsung galaxy s7 Verizon phone. I got The update one day and presed install and when it booted to the download screen it failed error code 410. does anyone know what this means?
Questa è una buona domanda?
Punteggio 2
1 Commento
When I open YouTube to watch videos it always says that troubleshoting code 410... What should I do?
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
You have violated Knox security. You cannot update a rooted phone.
Punteggio 3
3 Commenti:
Thanks ill un root to see if it does the update
da
What does error code 410 mean though
da
I haven't found a list of all the errors, but from the suggestions around the net, error 410 means download corrupt, or download interrupted.
There are some suggestions of Removing the google account and adding it back, format the cache partition, and try to redownload using a high speed wifi connection.
da
Preparati per le riparazioni future
Acquista tutti
When I press the samsung browser botton error 410 is shown provide solution
Punteggio 0
1 Commento:
Paramjit sf is my gmail account. But I forgot password
da
You could try flashing the update with Odin I don’t have the link handy right now unfortunately you would just download Odin on a windows pc download the Verizon 7.0 firmware connect your phone to the pc in download mode select the proper files for the proper sections and hit start. Look up Odin instructions on google first though. Sorry for lack of punctuation I’m on my spare phone after a screen failure waiting on the parts. Odin is basically a replacement for Ota updates for rooted Samsung devices
Punteggio 0
1 Commento:
I got the error and I'm not rooted. Never had an issue before.
The USA snapdragon variant can't be rooted anyways. At least not in a publicly known way. If it could I'd root because I can't stand the bloat or Samsungs customized version of Android.
da
Aggiungi la tua risposta
McOfficialPlayYT sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 15
Tutti i Tempi: 8,632
