Salta al contenuto principale
iFixit utilizza i cookie per migliorare le funzionalità del sito, analizzare il traffico e personalizzare gli annunci. Utilizzando il nostro sito, accetti l'uso dei cookie e l'Informativa sulla privacy.
The Samsung Galaxy Note 4 is a cellular smartphone that was released in October 2014. The Galaxy Note 4 Model Number is SM-N910, SM-N910A, SM-N910T, SM-N910V, or SM-N910R4 for American variants.
Replace digitizer from another Note 4 (not replacement kit)?
Is it possible to swap out the digitizer from another Note 4 in to my own device, without doing damage to the S pen functionality?
When you pry open the screen you apparently damage the copper film -- what is the purpose of this film, and does it damage S pen functionality?
The replacement screen kit everywhere I look is the same price as a used Note 4, or Chinese phone, so the only cost effective option is to buy a broken (for parts) device on eBay that has a working screen.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
I've done it before without any problems. Also, I think you're talking about the contact point for the digitizer on the glass.
As long as you're careful you should be fine. I frequently swap parts of devices. The only times I've had problems were my fault i.e. rushing, being careless, ect.
Good luck.
Punteggio 0
Preparati per le riparazioni future
Acquista tutti
Have same problem here. OLED is apparently fine but the digitizer is glitchy.
I did also find a crack in the top which *may* be why it had issues but can’t tell for sure until its completely removed.
Punteggio 0
I'm wondering the same. And John or Andre did you try this? And if so, can you share the outcome please. Thank you much.
Punteggio 0
Aggiungi la tua risposta
John sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 500
