Salta al contenuto principale
The Summer Infant 3D Lite is a stroller that features an ultra-lightweight design and easy storage capabilities.
Replacing the foam grip on handle
My dog chewed off the foam handle. How can I find and replace it?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
steph24w , Did a search for replace foam grip for your stroller and had no luck. I had similar issue with my lawn mower handle where the foam grip had deteriorated. To repair it I went to the hardware store and bought a 6 foot length of foam pipe insulation $1.50, cut it to size to fit my handle(it already has a open seam) so I slid it on and then wrapped the foam with electrical tape to keep in place and reduced the size a bit for comfort. You could do both sides to match. The foam can also be bought as a tape roll also. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Punteggio 1
Aggiungi la tua risposta
steph24w sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 29
Tutti i Tempi: 2,340
