Time keep changing after set in control panel
Time incorrect. It can be changed in Control Panel, but it will change again showing an incorrect time. Date is ok.
Questa è una buona domanda?
For this type of issue, there are only a couple of things I know of to check.
First, make sure you are set to the right time zone. This can usually be done as easily as right clicking the clock -> Adjust time/date -> Select correct Time Zone in drop down
If it keeps happening, I have solved this issue before by replacing the CMOS battery which seemed to be the culprit.
Hope this helps!
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 137
