Salta al contenuto principale
Quinta generazione dello smartphone android al top di gamma Samsung, rilascaito l'11 aprile 2014. I miglioramenti rispetto alla serie successiva comprendono lo scanner impronte digitali, la fotocamera aggiornata, lo schermo più grande e la resistenza all'acqua. Disponibile in quattro colori differenti: nero, blu, bianco e oro.
Why does it stop working when I get incoming calls?
When I get an incoming call, sometimes it just reads that the phone stopped working and when I press OK it pops up again and I can't answer the call and have to reset the phone completely. Is it a common problem and if so, does anybody know if and how it can be fixed?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
I would recommend connecting to Wi-Fi and make sure that your phone is updated to the latest version of Android OS available. Also check to make sure that your carrier settings are up to date as well. This can sometimes be caused by the Android software trying to use the Phone app and not having something that it needs to continue, so the app fails and shuts down. Hope this helps!
Punteggio 0
2 Commenti:
I tried updating the software but it still happens. Any other suggestions?
da
The only other thing I can suggest is to make sure all your apps are updated, if that doesn't work, try to *first* back up all your data you want to save... then to a factory data reset.
da
Preparati per le riparazioni future
Acquista tutti
Aggiungi la tua risposta
Bor Turnšek sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 76
