Salta al contenuto principale
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
20 Domande Visualizza tutte
Screen Cleaner on lcd panel?
Hi to all,
I am recently change my macbook 2008 uni-body screen to new one .When i am try to clean it, accidental I pure on the transparent apple logo some amount of screen cleaner. I am peal it off from the logo but, i am afraid of that this liquid is get inside the screen , and be inside on the lcd screen. I don't know if this is possible, but, because the screen is second hand and i am not test it before, for the black color performance, and now I notice that on black color or hard blue color, i can see a large blur line then a circle blur and then another blured line. all is blured and not very noticable. in other colors the screen is ok ... I don't know if this is a laptop screen problem or if it is caused by screen cleaner. Also I it from screen cleaner, If anyone knows if it is safe to try to clean it with hairdryer or other method , that will be helpful.
Thanks in advance .
Questa è una buona domanda?
Punteggio 0
5 Commenti
Does your original screen work? Also what screen cleaner did you use?
da
My original screen has problems and i am change it it was heated on the back
Also the screen cleaner is from luminia electronic devices is anti finger print leave on traces and repels dust said ideal for tvs and all types of screens. is not flammable and have less than 5% cationic . Also the liens is not contiues is look like small waves but in a line
da
I don't know if the logo is removable ,but it does not seem to be unsticked from its postilion. Is that may be other problem?
da
Can you send a picture of what it looks like? Have you checked that the connectors arent damaged and that they are plugged in all the way. Also what happened to your old screen?
da
Sorry for slow response i will post the picture sas soon as is possible i am try to find a camera to manage to get the picture and show the problem as well..
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Sounds like it is stained from the liquid (post a picture to double check), the liquid would have seeped into the backlight of the LCD, so you will need to replace it to resolve the issue.
Punteggio 3
photo is not very clear but is noticable
Punteggio 0
3 Commenti:
This screen is second hand so may have problems before installed... Is there any recommended heating temperature to heat the screen and not damage it eg with hairdryer , to see what is going wrong with this?
da
I have seen that issue on a lot of the older unibody models (either visible on a black screen or white one, outlining the Apple logo), not entirely sure if liquid causes this or if it is a fault with the LCD panel. Would recommend contacting the seller to be honest, see how they react
da
Ok... So other peaople have the same problem!!! I will Contact the seller then , Thanks for That!
da
Hey, what screen cleaner did you use? I think that this screen is second hand so may have problems before installed.
Punteggio 0
Aggiungi la tua risposta
ssavva05 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 173
