Salta al contenuto principale
La revisione del 2016 di Apple alla propria gamma di laptop indirizzata agli utenti professionali. Adotta un display Retina da 15" e 2880 x 1800 pixel, processore quad core Intel i7, opzioni SSD da 256 GB, 512 GB, 1 TB, 2 TB, 16 GB di RAM e tastiera dotata di Touch Bar. Rilasciato a novembre 2016. Modello A1707.
Is the glass in front of monitor replaceable?
Is the glass replaceable? i've noticed this model has more scrunchable glass that previous models. Can I pull it off with heat etc?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Yes it's possible to replace just the screen, it is basically the same process as replacing the LCD on the 12" Retina. After removing the assembly from the MacBook, heat and slide a thin tool under the bottom glass, then you can remove the screws for the hinge and start removing the screen. Would definitely recommend against replacing this unless you have replaced the LCD only in older models, a lot can go wrong.
Not really worth it at the moment unfortunately, LCDs go for 300$ if you are even able to get hold of them, which is far too expensive for an LCD. Wait till later this year, and they should become more available and drop in price.
Punteggio 3
Risposta Più Utile
I have not found anyone but @reecee in the UK, that seems to have has any success repairing the retina displays.
I heard he slashed his wrists with a WWII Sheffield SHE006 Fairbairn Sykes British Commando Dagger afterwards.
https://www.knifecenter.com/item/IXSF714...
Punteggio 4
1 Commento:
You heard right, I had 3 to do that day. Thankfully, I couldn't do any more after that incident ;)
da
Aggiungi la tua risposta
TJ Hellmuth sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 360
