Salta al contenuto principale
The Red Ryder BB Gun is a BB gun made by Daisy Outdoor Products and introduced in 1938 that resembles the Winchester rifle of Western movies.
How do I get a stuck BB out?
If a bb is stuck in the gun how do i get it out
Questa è una buona domanda?
Punteggio 5
11 Commenti
Where is it stuck?
da
I have it stuck in the clip loaded it wrong
da
Hey does anyone know how I can get my mag out of my airsoft pistol it is stuck beacause of a bb witch is blocking the mag plz help!
da
Lots of force, the mag is made out of steel, the BB is probably copper or something soft, the BB should give first, dont be shy.
da
I have a MK-177 BB gun with a loose bb that moves around whenever I move the gun and at one point the inside of the barrel feel out and I put it back in dont know if that has anything to do with it but other then that does anyone have any idea how to get the loose bb out its annoying the &&^& outta me btw lil tipsy when I made this comment sorry if everything doesnt make sense
da
Mostra altri 6 commenti
Aggiungi un commento
7 Risposte
Soluzione Prescelta
A'Leah Key , Get metal/brass rod slightly smaller than the bore diameter less then .177"/4.5mm, approx. rod size 5/32"or smaller should work fine. Make sure all other BB's are out of the reservoir and leave the door open, put a couple drops of oil in barrel, slide rod in the barrel from the muzzle until it hits the over sized BB and then tap it lightly with a hammer. The rods can be found at hardware/metal supply stores. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Punteggio 5
3 Commenti:
An old stainless steel radio antenna works too!
da
is there a way I can send it cause I can't fix it when I took the screw out the trigger went upside it won't come back down I could see that the screw I took out doesn't lineup even when I took it out the screw hole is to one side
da
i cant get the trigger back down
da
i recently had same problem with red ryder bb gun . I was able to remove the plastic front sight by bumping the back of the sight. Then with needle nose pliers twisting and gently pulling inner barrel out. I found a stiff wire about the right size and attempting tapping the obstacle out, but didnt move much. luckily I was able to drill the object out because it was near the input end of the barrel. I believe it was a misshaped bb or two. I put the barrel back in by pushing it with a little force and twisting it. then simply snaped the plastic sight back into place. The sight looks like it has a screw but it is only plastic cast. The outer barrel is slotted for it to slip into.
Punteggio 2
usually a small dowel the size of the barrel will work poke it in the front end to the back
Punteggio 1
Use ur hands and get it
Punteggio 1
If it is in the barrel of the weapon then using a metal thin line or something small but agile that can fit through the barrel to push the BB back into the loading chamber(or reverse) should work. Make sure the magazine is out so that the BB just falls right out. If it gets stuck at the back of the barrel and is unable to fit through the loading chambers transfer hole I would then recommend either deconstructing the gun so that you can get at the BB or bring it so a store that can repair it. If the BB is stuck in the magazine because you loaded it improperly, your best bet is take apart the magazine to get at the misplaced BBs unless the magazine in this case has a released lever so that the BBs can simply drop out of the magazine.
Punteggio 0
guy so i have a D93 uzi and whe i try to shoot it nun comes out andthe batter starts to get hot too can you guys help me fix it
Punteggio 0
i have a daisy airsoft bb gun and my mag is stuck and it wont come out
Punteggio 0
Aggiungi la tua risposta
A'Leah Key sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 44
Ultimi 30 Giorni: 141
Tutti i Tempi: 42,639
