Salta al contenuto principale
A tablet developed by HP in 2011 running the webOS platform. Boasts a 9.7" display, and is available in 16 or 32 GB. Repair is straightforward, but requires time and persistence.
Display problem in middle of display
My display has developed a 2" bar across the middle that is all garbled or fuzzy meaning you can't read or see what is supposed to be there. Otherwise the unit works well. Is there a way to fix this problem? Thanks in advance for any help
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
likely the pins in your LCD connector are likely built up with dirt. Open the device, remove the LCD connector. use a toothbrush and 99%isopropyl to scrub at bot the gold traces at the end of the flex, and inside the female connector of the board. Air dry for 10 minutes, and reconnect.
This SHOULD Fix your issue.
If it does not, either the flex is damaged, or the connector on the mother board is damaged.
-if the flex is damaged, replace the LCD
-if the connector is damaged, remove the connector, and solder a new one onto the board. (This last step is a more difficult procedure, and without SMT Soldering experience, i would suggest taking it to a professional.)
Punteggio 0
Parti & Attrezzi Popolari
Aggiungi la tua risposta
Peter Mather sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 112
