Salta al contenuto principale
port is changing automatically
guys,
need help. I use "mail". I always use port 993 for incoming. suddenly from yesterday i am having problem. the port is automatically changing. and I can not see mold mail, also mail is not downloading to computer.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
TCP ports can get a bit confusing. Outbound connections use ephemeral ports which can be anything above 1024 that is not used.
Your ISP will give you the mail server's TCP port to connect to. Here is the listing of Common TCP/IP Ports.
Most mail servers which offer POP3 use 110 or for IMAP use 143 ports. To use SSL/TLS encrypted ports: POP3 uses 995 and IMAP uses 993. Its also possible your company uses their own port assignment to help protect their firewall.
Now to confuse you! You'll need to check with your provider if they offer IMAP services. Many only offer POP3 and if you want IMAP you need to pay more for the service.
Most likely your ISP bounced you from IMAP to POP3 either because they no longer offer it or you have to pay the premium for it and hadn't.
Punteggio 2
1 Commento:
I should add:
Private email systems often move their servers TCP port to hide it from attack from the internet.
In addition where you are could also be blocking the ports as they don't want people accessing their internet resources. They may want to offer access to their private web server so you can use it to order what they sell or read up about an item. As an example: a gallery or museum offers a web site so you can read up about the artist or their pieces. It could even host a silent auction bidding solution.
da
Parti e strumenti correlati
Aggiungi la tua risposta
shamaun1 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 60
