Salta al contenuto principale
The Brother MFC-3240C is a 5-in-1 color inkjet printer.
Printer is not printing
My Brother MFC-3240C is not printing. I have not used it for a few years. I've run the clean 5 times and my black level indication has gone from full to minimal. The printed page has no ink on it what so ever. What do I need to do to get this working? Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
@marklk , Mark, I do not own this printer. Probable clogged print head. Remove the print head if able and soak it in 90%+ Isopropyl Alcohol. Then use Qtips/soft cloth dampened with 90%+ Isopropyl Alcohol to clean all of the remaining ink-paths that exist in the printer. Links below may be of help. Good luck.
Come pulire gli ugelli della testina di stampa a getto d'inchiostro Brother
http://www.inkmagic.com/shopcontent.asp?...
https://www.youtube.com/watch?v=gQZ3ex0b...
Punteggio 1
Aggiungi la tua risposta
Mark Kline sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 156
