Salta al contenuto principale
The Acer Aspire E1 series is a line of notebook laptops manufactured and sold by Acer, Inc., an electronics corporation based in New Taipei City, Taiwan. The Acer Aspire E1 series was introduced in 2012.
Location Unavailable when trying to access docs
I went on my laptop and then tried to open my documents to access and Excel/Word doc and it says "Location unvailable"
Questa è una buona domanda?
Punteggio 0
1 Commento:
Have you tried browsing to the folders with the documents you are trying to open? What operating system are you using?
da
Aggiungi un commento
1 Risposta
Hello Warren
  1. If you hold your windows key and then tap R you should get a run box.
  2. In the run box type %userprofile% and then click OK
If this doesn't work try this
  2. In the run box type C:\users and then click OK.
This should open a windows with a list of profiles on the computer. Double click on your user profile and you should then see your document folder.
Hope this helps
David
My Computer Dude
Punteggio 0
Aggiungi la tua risposta
Warren Fernandez-Williams sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 8
Tutti i Tempi: 81
