Salta al contenuto principale
The Samsung Gear S, model number SM-R750, is a smart watch which pairs with your Android smart phone. The Samsung Gear S was released in October 2014.
Why is my gear S does not pair?
I baught a gear s and i tried to pair it with my galaxy S6 and my device doesn't find it in gear maneger... i tried to pair t with another device and still have the same problem... i tried to format it and i updated it from samsung kies still have the same problem???!!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
bara qubbeia , According to the list, link #1 below the phone should connect to galaxy S6 , maybe factory reset and follow instructions in link #2 or link #3. Still no go, return watch under warranty for replacement/refund. Good luck.
http://www.samsung.com/hk_en/mobile_comp...
http://techlife.samsung.com/pairing-gala...
http://samsungrumors.net/use-gear-s-andr...
Punteggio 2
2 Commenti:
L Pfaff
Thank's for your answer but unfortunately still have the same problem
I think i will go to samsung store to check it....
da
bara qubbeia, Yes, while under warranty return to store, as the watch should pair for you. thanks for replying back, good luck with your watch.
da
Parti e strumenti correlati
Acquista tutti
Aggiungi la tua risposta
bara qubbeia sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 224
