Salta al contenuto principale
Modello A1136 con 30, 60, o 80 GB di hard disk con plastica frontale bianca o nera
Stuck on Very Low Battery message
My 30 GB 5th Gen iPod gets stuck at the "Very Low Battery" screen, and won't boot up. iTunes won't recognize it, resetting doesn't help, and I can leave it charging for days and it'll still say "Very Low Battery".
Will replacing the battery help, or is this a sign of a bigger problem?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
My iPod Classic 5G 30 GB is over 11 years old, came up with the "Please Wait, Very Low Battery" message, very faintly. The faint Apple icon would come on sometimes, but the iPod wouldn't play or charge. I ordered a new battery, but, in the meantime, found a fix on line, implemented last night. I held down the upper ring and center button for ten+ seconds, until the faint Apple icon came on, then plugged it into a wall charger; After a bit, the bright Apple logo came on and remained for about 30 seconds; I left the iPod charging overnight and was pleased/thrilled to find the battery icon and 'Charged' on the screen. It boots up to the 'menu' screen, syncs with our old iMac and plays in our Sony dock. I reckon the iPod had its battery run down too low and got stuck.
Punteggio 1
2 Commenti:
I am aware that the post is around 6 years old by now, but did you charge the iPod over night with a usb 2.0 type of plug, or was it a firewire type plug? My iPod has the exact same issue you're describing, and it would help tons, thank you!
da
@daniel35124 you should try what Saul123 suggested on August 5, 2007, this helped me to revive iPod Classic 5th Generation 60GB that's been sitting for 10+ years, I even didn't have to swap the battery. Here's the link — https://discussions.apple.com/thread/955...
da
Parti e strumenti correlati
Acquista tutti
Ryan, start with the battery first. It's the cheapest way to determine if there are other issues. I have previously had one of those on my ipod and after replacing the battery the error was resolved. I would only suggest to restore the iPod as soon as iTunes recognizes it. Good luck.
Punteggio 0
Aggiungi la tua risposta
Ryan S sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 44
Tutti i Tempi: 6,493
