Salta al contenuto principale
Released in February 2014. A Garmin manufactured GPS multi-sport training watch with illuminated display.
Start/Stop Button Not Working
Start/Stop Button Not Working. All other button function.
Can the start/stop button be replaced?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
@alistair , Alistair, Use the disassembly guide below to take your watch apart and clean the buttons perhaps if need be then you will have access to change buttons. Use a soft cloth or Qtip dampened with 90% Isopropyl Alcohol to clean around the buttons and contacts. Good luck.
Garmin Fenix 2 Motherboard Replacement
Punteggio 2
Preparati per le riparazioni future
Hi, i have the same problem on my GARMIN Fenix 3, You think the solution is the same ?
Thanks
Punteggio 0
Aggiungi la tua risposta
Alistair sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 29
Tutti i Tempi: 14,577
