Salta al contenuto principale
how to restart a lazy mac
my powerbook g4 15"does not restart immediately after shut downs.
it does however restart after waiting 8-10 hours. strangely, if i disconnect the power after logging out, (without shutting off the unit) it restarts immediately. must point out that battery doesnt hold much charge anymore and the mac must be connected to the ps all the time. i wouldn't want to buy a new battery unless i am reasonably sure that it would solve the problem. have already changed to pram battery.
any suggestion ?
thanks and happy new year to all
francesco
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Have you tried resetting the power manager? Instructions are here:
http://support.apple.com/kb/HT1431?viewl...
I would also zap the PRAM (though changing the PRAM battery would have effectively accomplished that) and reset the NVRAM, just for good measure.
Zap PRAM: reboot while holding down command, option, P, R. Keep holding them down through 3 chimes.
Reset NVRAM: reboot while holding down command, option, the letter O, and F (this boots you into Open Firmware, which only works on PPC Macs.) You'll get a white screen with black text. When the text stops spewing, type "reset-nvram" and Return. Then type "reset-all" and Return, whereupon the computer will reboot itself.
If that doesn't help, you may have a hardware problem of some kind.
Punteggio 3
1 Commento:
Thank you Dear Colleen, it was very helpful. Best Regards, Martin Svika at mejelgava@yahoo.com
da
Parti e strumenti correlati
Acquista tutti
When you say my powerbook g4 15"does not restart immediately after shut downs.
it does however restart after waiting 8-10 hours.[/quote].
Sounds like warping of the logic board, and cooling resets the warp. You could try to shim the board, or look for solder joints that need reflowing.
If that's too much work then replace the unit it's long overdue.
Good Luck,
N.
Punteggio 1
Aggiungi la tua risposta
Francesco sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 12,267
