Salta al contenuto principale
The HP Envy dv7 is a Windows 8 laptop that features a 17.3-inch screen.
16 Domande Visualizza tutte
laptop is very hot and has a high pitched squeak
My laptop gets very hot and makes a high pitched squeak.
How do I fix it?
Questa è una buona domanda?
Punteggio 0
1 Commento
It is probably the fan. Remove the bottom case and check the fan for obstructions and dust. The fan should spin freely, if not then replace it. The next thing to do is to remove the heatsink from the processor and clean the old heatsink compound off and put in fresh heatsink compound onto the heatsink (apply a small amount, too much will just get squeezed out).
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@lasdisc , ANDY, It very well could be a dirty fan or a faulty fan. You can use the links below to assist in opening the computer to access the fan, heat sinks, board etc. and give the inside of the laptop a thorough cleaning as shown in the 1st link. 3rd link is your service manual. You should try to isolate where the noise is coming from before opening the laptop, by chance that it is not the fan. If fan is not spinning freely or you may just not trust it, maybe just replace it for piece of mind, Link #4 shows replacement fan, which you can also do a search on for better pricing perhaps. Good luck.
https://www.youtube.com/watch?v=ZT0ovCnt...
https://www.youtube.com/watch?v=VvJwlTcp...
http://www.hp.com/ctg/Manual/c03591253.p...
https://www.amazon.com/FEBNISCTE-dv7-721...
Punteggio 3
Aggiungi la tua risposta
ANDY sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,360
