Salta al contenuto principale
This iteration of Amazon's Kindle Paperwhite series was released on June 30, 2015. The Kindle Paperwhite 3rd Generation is a 6-inch, 300 PPI reading display tablet that is Wi-Fi capable. The designated model number is DP75SDI.
How to replace charging port
Kindle Paperwhite 3rd edition, need to replace charging port, metal prongs are bent
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
here are the guides for the kindle paperwhite 3rd gen tablets. this doesn't say exactly how to replace the charging port but it do do the motherboard. looking at this guide you can figure out where the connections are for the papaerwhite and replacing something like the charging port would require some soldering i think. I hope that this helps and you are able to charge your device soon
Kindle Paperwhite 3 (7th Gen)
Punteggio 2
I've been told my kindle white port can't be fixed
Punteggio 0
Aggiungi la tua risposta
hgileskohler sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 4,504
