Salta al contenuto principale
The Gateway NV52 was released in 2008. It is similar to the MS2274 and NV5207u models.
15 Domande Visualizza tutte
which monitor controller can I use for this laptop
My laptop stopped working, and I'm not interested in fixing it, but I want to use the monitor as a second display for my station, but I need a controller [if I understood correctly], can someone instruct me which controller to get?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@carrotsy that will depend on your display panel, not your computer. Disassemble your dispaly to the panel and take a look at the label on it. Most common panel for your model is a B156XW04 (there are different version recognized by the V.X number on that label. With that number do a search on either Alibaba.com or ebay.com for a "universal LCD controller board". You should find something like this. Again, always double check your LCD panel. To connect the kit is actually pretty easy. Check this guide for a bit of an idea what you are getting into.
Punteggio 2
2 Commenti:
I guess I was wrong again.
da
@pccheese not wrong you just have not build one yet. You are getting there, reps are looking good.
da
Aggiungi la tua risposta
Salah sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 150
