Why does start squealing
my toshiba satellite a300 starts squealing after the logo screen
Questa è una buona domanda?
squealing is usually caused by the fan as it starts up due to heat from the processor booting everything up ...fans are easy to replace and cheap if you search what fan is needed via google with laptop model you'll be able to locate one easy enough and then its just a case of removing the screws holding the base cover.
unplugging the plug for the fan replacing
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 179
1 Commento
Hey there!
I was wondering if you could be more specific with your question. Are the speakers "squealing" or is it the fan that is making noise? Isolating the source of the sound will likely point you in the direction of the issue.
All the best!
da Alex Soria
