Salta al contenuto principale
Install SSD HD in PowerBook G4 1.5?
PowerBook G4 1.5 12" has a Fujitsu MHT2080AH 75GB HD that is failing.
Can an SSD HD be installed in the Powerbook?
If so, what specs do I need to be aware of?
Will a KingSpec T-60 SATA III 3.0 HD work?
Does it need any kind of adapter? or spacer?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
No. Your machine uses an Ultra ATA/100. Even trying to find a new one of these will be very difficult (I've looked and have not found one yet, only used.)
update - here's a new one: http://www.newegg.com/Product/Product.as...
http://www.everymac.com/systems/apple/po...
Punteggio 3
2 Commenti:
Does it matter if replacement HD is more than the original 80GB?
Will ATA/33, ATA/66, ATA/100, and ATA/133 work with Ultra ATA connection?
If drive is only listed as PATA/IDE, is there a way to tell if it is Ultra or other faster ATA speed?
(ATA/33, ATA/66, ATA/100, and ATA/133)
da
No, but I would stay under 2TB. The last limitation I remember was on G4s and as 120GB.
da
Preparati per le riparazioni future
Acquista tutti
Actually, if you are willing to build your own IDE drive you can do so as follows:
# Buy an mSata of the size you need. mSata’s are miniature SSD Sata drives https://www.amazon.com/gp/product/B07GZF...
  1. Buy and IDE to mSata converter in a case form https://www.amazon.com/gp/product/B01GRM...
  2. Put the two together and you have a SSD IDE drive
  3. Find instructions for installing an IDE in the 12” power book and away you go.
Punteggio 1
Aggiungi la tua risposta
dstx sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,320
