Salta al contenuto principale
A Big Wheel is a type of tricycle, usually made of plastic, with an oversized front wheel, that rides very low to the ground.
Steering column is stiff
I recently put together a kids big wheel and the steering column is very stiff and will hardly turn. Obviously this isn't something that is adjustable given the set up, but I need simple solution so my three year can steer it. Thanks!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Try adjusting the height of the handlebars by loosing the screw in step #5 of this PDF and lifting slightly till it turns freely then tighten it back down:
originalbigwheelparts.com/images/bw_assy_instructions_pictoral.pdf
Punteggio 2
4 Commenti:
Kristina Johnson, This may also help, take the column back apart and apply a little/ thin coating of Vaseline on column and reassemble. Good luck.
da
Neither of the above helped a bit. Cannot be steered by a child.
da
Item is a piece of junk.
da
Agree, the Big Wheel has been unused for over a year. Every few months my kids and their friends get on it and just as quickly get off. I would greatly appreciate someone sharing a fix if there is one out there
da
Aggiungi la tua risposta
Kristina Johnson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 23
Tutti i Tempi: 1,738
