Salta al contenuto principale
The Jeep Cherokee (XJ) is a compact SUV that was manufactured and marketed by Jeep from 1997 to 2001. Sharing the name of the original full-size SJ model, but without a traditional body-on-frame chassis, the XJ instead featured a light-weight unibody design.
Intermittent stalling immediately after starting or punching gas
There is gas, the starter is fine, the battery is good. It doesn't matter what temperature the engine is or how long between starts but if I rev up the engine while cranking it starts okay. Rarely I have to rev at stops or the idle drops too low and stalls. If I punch the gas very quickly it revs and drops quickly and then stalls. Starting has a success rate of about 50% without revving. If it stalls, I must rev the engine to start.
Questa è una buona domanda?
Punteggio 10
18 Commenti
check to see if there is a hidden fuel filter in a black plastic housing in the frame rail between the fuel tank and the pressure fuel pump. It has 4 fuel line ports. Use a band type (oil filter) wrench being careful not to break the plastic bowl unscrewing it. Its tight to unscrew, I had to slightly bend my brake-line out of the way. The filter inside is 1 1/2" tall by 2 3/4" wide.
da
after finding this hidden filter, My truck has been running like a top, U would think, The big filter would do the first main filtering, and the small filter would be the after filter, but not on this ford, the housing doesn't like it unscrews having a filter inside, Its been missed over the 20 plus years, I'm sure this was why the prior owner sold it giving up trying to solve this problem of stalling out starting back after setting awhile purring like a kitten for the next few miles then repeating over,
da
Help!!! I have a 98 jeep grand Cherokee. Now while in park I pump on the brakes and it starts to feel like it wants to shut off. Can anyone help?
da
Victor, I may be wrong, but that sounds like a vacuum leak from the brake booster. It's most probably a cracked hose.
da
I have a 99 Dodge Ram that my engine won't stay revved up if I mashing the gas pedal to the floor it surges what could be causing it to lose power and then rev back up repeatedly. It's like a cell phone on vibrate. Whole story, it had just rained here and I stopped to fill my tank at the station,. Immediately 1 block away I started having issues, loss of power, popping and cackling, I assumed bad gas. I put gas treatment in and sea foam revving it up and down trying to burn the water out it died a couple times kept revving it up and eventually it start working its way out it's still backfired and still really didn't have much power so I push the pedal to the floor and got it running at high RPMs and then that's when I noticed that it surges.
da
Mostra altri 13 commenti
Aggiungi un commento
12 Risposte
Soluzione Prescelta
If you feel that the fuel pump has failed, then this is the proper way of diagnosing the problem before replacing an item that may not be needed. Starting from the basics, take off the fuel cap and listen closely for the fuel pump to come on as a helper turns on the ignition key. The pump runs for only 2 seconds at a time when the engine is not running. The computer shuts the power off to the pump if it does not see a signal from the crankshaft sensor.
Have the helper turn on the key for 3 seconds and off for 5 seconds and on again a couple of times. If the pump cannot be heard, then replace the cap and lift the hood. Check to see if the fuse to the fuel pump is good. If so, then look to see if fuel is the problem by removing the cap on the Schrader valve on the fuel rail on top of the injectors. Take a small screwdriver and push in on the Schrader to see if fuel comes out in force. If not, hold the Schrader in and have the helper turn the key on. Be ready to release the Schrader if there is fuel pressure, for it will come out fairly steady. If there is no pressure, replace the cap and check the relay. Remove the relay and test the terminals that it was plugged into for power with the key off. There should be one terminal with power. If not, there is a bad wire under the fuse block to the battery; it should have constant power at one terminal.
Take off the air cleaner and hold the throttle plate open with your hand. Spray some carburetor cleaner into the throttle body. Try to start the car for 2 seconds. If it starts, the fuel pump is the problem. If not, the engine should be checked for spark. It could be a sensor or computer-related problem. To be absolutely sure, raise and support the back of the Jeep on jack stands, unless the height allows you to crawl under the back without raising it. Unplug the fuel pump connector at the back of the fuel tank. It will be easy to find and has four wires in the connector. Use a circuit tester and test the harness side for power as your helper turns the key on and off. Remember that there will be power for only 2 seconds, so have your helper cycle the key on and off as you check the terminals, allowing 5 seconds between cycling for the computer to reset. If there is power, the fuel pump took a dump and needs to be replaced. If there is no power, there is an open in the harness to the pump from the fuse block.
Let us know your results and we can go further.
Punteggio 10
4 Commenti:
great answer +
da
This is what we did, but turned out that the pump has slipped up from the gas tank floor, and now I need to keep the fuel filled a little higher, and fill more often, 2.5 gallons of gasoline solved my problem. Yey for mechanic neighbor!
da
What if you do hear the fuel pump turn on for 2 seconds when the key is turned? What if there is fuel under pressure when you release the schrader valve and it squirts out? Is it still possible the pump is bad? My engine won’t rev above 2500 rpm, and drops to about 1200 when it revs back up to 2500 under a steady pedal/throttle. I’ve changed the TPS, all plugs, and the coil pack on my 2001 Cherokee. Running out of ideas.
da
Sometimes a fuel pump will have pressure but no volume..hook up a propane tank to a vacuum hose from the manifold start step on gas pedal then turn on propane it it revs normal change you fuel pump...
da
My Jeep lives... no thanks to Chrysler engineers. I have had an issue with my Jeep randomly stalling for about 3 years. I researched the internet, Jeep clubs, and spoke with several mechanics. Needless to say everyone had a different solution. It ended up being the wire going from the Alternator to the battery and fuse box. Something none of the experts even considered.
Those of you who know about wiring... Chrysler engineers used 8-AWG wiring from the alternator and 6-AWG for the starter and the negative/ground. I discovered an issue with the wiring after I had played the role of a typical mechanic; testing and swapping out all of the usual culprits. I connected my 1/0-AWG jumper cables between my Jeep and my car. When connected, the Jeep ran OK, it stalled every know and then, but would start back up after a few seconds. If I disconnected the cables, the Jeep would die with in 5 minute... every time.
So... I tested the alternator. It was operating perfectly. So, why was my battery going dead? And, why was my Jeep dying? I removed the flexible plastic cover from the wires coming off the battery and the alternator to discover, (a) they were unusually small in diameter and (b) they had several burn marks along the wire run.
I have enough of a background with electronics to know that the skinny little wires were overheating and causing a drain on my electrical system. Think of running a compressor with a cheap extension cord... you get the picture.
I replaced all of the cables with 2-AWG, 300 amp, 680 strand welding cable. A little overkill, YES. It works beautifully. Love my Jeep. Total cost was $90 including tools.
Punteggio 5
4 Commenti:
Hi,
Glad you love your Jeep. Others are not that impressed with them!
https://www.youtube.com/watch?v=yVM3QX2G...
da
Update... after fixing the wiring, I discovered a secondary problem. The REDTOP Optima battery was over heating. I have had this battery replaced under warranty 3 times. I am now using a different battery.
The Optima battery was shorting out internally, causing the battery to get hot and trigger the "Battery Temperature Sensor". This along with the less than adequate factory wiring is the actual culprit which caused my Jeep to randomly stall. I discovered the battery issue after upgrading the wires.
I am currently running a no-name battery and have not had a stall since making the change.
da
Beware the Optima batteries. Some years ago they were all the rage and actually did perform reliably. In the last number of years the quality has disappeared. I've been in the industry quite a few years and am telling it first hand: it happens a lot and it's usually more than one warranty replacement. Very well built AGM batteries almost never have "issues." Spend your money wisely and you won't be left sitting somewhere Murphy sees as suitable. Look for a 5 Year Full replacement warranty with ZERO prorating. If you do have one of the Optimas be very careful leaving a high rate charger on the battery unattended. Never use high rate chargers for more than a few minutres on an AGM battery (never more than 10 amps) or it will overheat and it's life will be shortened. Long slow charges (5 amps or so) are the best and DO NOT buy a cheap charger. Look for a NOCO charger designed for AGM battery maintenance and long term storage charge.
da
I wanna say thank you so much!!!! Honestly I can't say it enough.
I live off a fixed income and when I have car problems, it's a financial crisis.
So for the past 6 months I've had to put parts on due to my jeep stalling and dying.
I saw your post, so we went to the junkyard and stripped off a alternator wire. Wired it into my jeep and since.... No stalls, fires up first time. Omg!!! Thanks. I still have a shudder but I hear a vacuum leak somewhere. So we also got some lines from the yard too.
We bought this jeep for $1800 and for 16mos, we have put $2100 into it. So it's practically new. Now working on small things.
da
I hope you have had this fixed by now, but on my 2000 Jeep Cherokee Sport I had the same issue and it was the Throttle Control Module.
Punteggio 3
1 Commento:
Hi my Jeep grand Cherokee 2001, has stopped on the road , technician told finally car euc has damaged, we replaced same number of euc, but it starts , when I exelator car get stop, can some one help what is problem. Thx
da
start with the obvious.... any check engine light codes?
from there is to determine if this is an electrical issue or mechanical issue. using a fuel pressure gauge on the fuel rail can tel you if the fuel pump is not supplying enough fuel pressure. if thats fine, then check for vacumm leaks. how old is the jeep? older ones rely a lot on O2 sensor for the proper idle and if the sensor is bad, it can cause the described symptoms.
if all that is good, then do a compression test and a leakdown test. that will tell you if you have any mechanical issues with the engine.
cars only need air/fuel/spark.... if all are present is that they arent being used properly because a system is not working right
Punteggio 2
2 Commenti:
My my 1990 Jeep Comanche 4.0 will start right up and then about 30 seconds later it will try to stall but catch its self just before stalling I was messing around unplugging sensors and got to the O2 sensor unplugged it and no more stalling I love my jeeps I have a 88 Jeep Comanche 89 Jeep Comanche 1990 Jeep Comanche and a 1996 Cherokee Country high output lifted up real nice 215000 miles on it and it purrs like a kitten getting ready to purchase a few more I'm addicted something about them square bodies there so sexy good luck fellow jeepsters
da
Hi proud owner of a 88 comanche too.
I´ve had issues with my MJ for the last month . Already replaced the IAC valve, fuel filter, spark plugs and wires, cleaned the throttle body, new air filter.
Problem is that when driving on a rough street or past a small bump and the car gets a bit shaky it begins to fail and tries to shut off. Any idea on what could be the problem?
da
I have run into this prob many times if you have cleaned the throttle plate
Well you may want to try my fix.
I'm a 28 year mechanic and repair this problem on many jeeps, fords,
Chevys ect.. What you can do is drill a small hole in the throttle plate
About 1/8 - inch be careful pu a rag or towel to catch shavings. Put the breather assembly back on and test drive to relearn computer .
Problem should be solved. I also have noticed lots of the newer
Models of cars and trucks already have the hole drilled. Good luck
Brad. Greesemann
Punteggio 2
4 Commenti:
Brad you won't be working on my stuff. That is a shadetree fix and NOT acceptable.
da
if it works do it.
da
Where do you think engineers get there ideas?
da
Being a mechanic we have to solve all the fups engineers design.
da
I had a similar issue after I swapped the intake manifold & power steering pump from a 1999 Jeep to my '95. When accelerating quickly (onto the freeway for instance) it would stall. I would pull over and it would restart fine. After sticking my head back under the hood, I figured it out: Since the intake manifold was different, the vacuum fittings were different also. When I checked the engine codes, it was giving an error about the MAP sensor input. One of the vacuum hoses were not tight. I also found that the vacuum line going to the FPR at the front of the engine was contributing so I took it off and all has been well since then.
Bottom line: troubleshoot your vacuum lines and the things they connect to/from. If it's stalling when you punch the gas, it points to fuel pressure but your symptoms also point to a vacuum leak.
Punteggio 1
Sounds like John Hanks is right, throttle position sensor.... take out the sensor or get access to it by removing the intake so you can see down into the throttle body.......and clean the heck out of it. If the problem is better (rough idle or low idle), safe bet the throttle position sensor is the issue and they are easy to replace..... if you know someone that has one, you can also hook up one of those diagnostic computers and tell it (the jeeps computer) to raise the idle speed, if it won't do it = throttle position sensor is to blame........ I have one of these jeeps, and the crank position sensors can go bad too, fairly common actually......however usually they just won't start. (since the computer doesn't know what position the crank is in)...... this sensor is also fairly easy to replace..... just hard to reach.
Punteggio 1
My 2000 4.7 JGC is acting similar. I pretty much have to keep my foot on gas pedal (even while braking) or it dies-but it starts right back up. Other times, it takes a bit and will even start without me turning the key. We haven't read a definite fix, but keep reading that people are suggesting we alter the screws to the PCM [add washers, cut screws] or to look inside to see if solder is damaged. Others say to change crank aND cam shafts positioning sensors. We've done this... but with auto zone parts. We are so lost. Anyone have any thoughts?
Punteggio 1
2 Commenti:
I had that same problem with my stock supercharged 1.3L VW Polo G40. I had to keep foot slightly on the gas, everytime the rpm dropped from a quick stop at a red light or just being parked, no matter how cold or hot the engine, or else it would drop way below 1k rpm and eventually stall completely. I solved the problem by simply removing the throttle body and doing a good cleaning with carb cleaner spray. Also re-tuned the throttle position sensors and the idle screw. I suspect there was some residue breaking the contact from the throttle sensors somewhere, though I can't really tell where exactly. Thankfully, It is running fine and smooth now!
da
Samantha were you able to fix the problem? Did you try all of the repair suggestions that you mentioned?
da
From Perth in Australia, we have a 2003 JEEP Grand Cherokee Limited V8 with third of a tank of petrol and the engine cuts out going out of the turn of LH & RH corners. So, foot off accelerator coming up to the corner and braking, then as foot is reapplied to the accelerator to power into the corner, the engine doesn't sputter but cuts out, in some cases for a second or so, then regains normal revs. In another case, the engine had to be restarted by key to regain momentum which can be extremely dangerous going around a corner.
Punteggio 1
My 89 jeep will idle fine but as soon as I put it in gear and start driving it spits and sputters and sounds like it's loading up but definitely cutting out. I put a new carb, and new plugs in it I can't find the right cap and rotor for it anywhere.. Please Help. My husband past away so it's all on me now..
Punteggio 1
I have a 2004 Jeep Grand Cherokee Laredo straight 6 I’m not mechanic by far so please I have to ask questions since the Jeep is all I ha e to drive and Its up to me to get it fixed I guess since I have know help by hand because I guess friends and so called friends are more important then our family itself so please I’ve been laughed in my face enough I need a little help I know very little about motors but I do know a little from helping daddy when I was growing up thank god which is very sick with C.O.P.D . Last stage that is I have to take him back and fourth to the doctor and everything in this Jeep so now all that being said all I’m asking is for a little help no hand outs I’m willing to try like !&&* on my own if there is a will there is a way is what I believe….. thanks to god that is ………
Punteggio 0
1 Commento:
I need yalls help my 89 yj will idle great but I put it in gear and start driving it starts spitting and sputtering like it's loading up. I put another carb on it and plugs but can't find the right distributor cap and rotor for it, it's not what it calls for, so there for they keep giving me the wrong parts.
da
Hi Nancy it sounds like a bad or plugged up catalytic converter causing your issue it’s not letting the engine breath so cuts out sometimes won’t show codes for that but hopefully it solves your issues let me know if it fixed or not .?
Punteggio 0
Aggiungi la tua risposta
Mike sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 62
Tutti i Tempi: 293,104
