Salta al contenuto principale
The Asus ZenPad S8 is an 8-inch Android tablet by Asus. Released in June of 2015. Model number: Z580CA.
wifi does not work
I need help with my Asus z580c, the wifi is like death, it does not work, you start it but nothing happens, when yo seek into hardware info, it appear wifi undetermined
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
i solved, open the table, disconnect the battery, remove the sd card put it on again, reconnect the battery.
Ah voila there is again the wifi connection.
Punteggio 1
1 Commento:
this helps, thank you. i took it to power off, removed sdcard, restart and its working.
da
Preparati per le riparazioni future
I just powered down and removed the SD card and that fixed the problem.
Punteggio 1
Aggiungi la tua risposta
Jorge Herran sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 668
