Salta al contenuto principale
The VTech InnoTab 2s is a kids education tablet that teaches them to read, write, and think logically and creatively.
Why is my device not playing any sounds?
My device will not make sounds when there is suppose to sound.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Risposta Più Utile
If you're playing a video, music or any other media that normally has sound but you can't hear anything consider the following suggestions.
Check to see if you have your volume turned up all the way to 100%. If your volume is up and you still have no sound then plug in a pair of headphones. If you hear sound from the headphones then you most likely have faulty speakers on your tablet. Consider replacing the speaker on your VTech InnoTab. This guide can help you with that replacement.
Punteggio 2
Aggiungi la tua risposta
Paul Bednarek sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 28
Tutti i Tempi: 849
