Salta al contenuto principale
Repair guides and support for the ZTE n817, also known as the ZTE Quest.
How to fix LCD screen
I dropped my phone and the screen went white, but everything else still seems to work. The phone still viberates when I get a notification and the power button still works. The only thing wrong is the LCD screen. I want to know if something may have come unplugged and if so, what came unplugged. I may just need a new LCD screen
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Sounds like the LCD is done for. However try turning power off for a few hours while on charge and then turn power back on if screen still the same get a new LCD as swap it out
Punteggio 0
1 Commento:
it could also be a loose/disconnected cable. open up the phone and make sure all cables and connectors to the lcd are correctly in place
da
Aggiungi la tua risposta
Grace sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,520
