Salta al contenuto principale
Repair guides and support information for RCA-brand tablets.
Password change on the tablet
When u turn on screen is locked how do I change that password
Questa è una buona domanda?
Punteggio 7
1 Commento
How do i reset the password on a Rca Voyagerlll tablet
da
Aggiungi un commento
6 Risposte
Risposta Più Utile
You will need to do a hard factory reset.
• First, switch your tablet off.
• Then, power the tablet back up by holding down the volume (either + or - ) and power buttons simultaneously.
• Continue holding the volume button until the screen says "Booting tablet in recovery mode."
• This will give you a picture of an Android.
• Tap the android, and you will be given a screen with several options.
• Move between the options with the + and -, and select with the power button.
• Go to the option for Factory Data Reset and select it.
• Scroll down to `the Yes, and then the tablet will erase its memory back to factory settings.
• Once it has completed, select Reboot Tablet Normally.
Punteggio 3
2 Commenti:
I have the same problem but it's on a RCA Cambia W101SA23. I have tried the instructions above and I am not able to reset it cannot get into Factory hard set, can anybody help?
da
You may need to contact RCS's Customer support at 1 (800) 968-9853
da
Parti e strumenti correlati
I am locked ot of my RCA Galileo Pro tablet. how do i get in to fix my password?
Punteggio 1
5 Commenti:
You still need to do a data factory reset. See my post above for directions. This will erase all the data.
da
da
I don't remember the correct code
da
What will happened to my contract and what up.
da
Would I get back my child Google class
da
My phones is not working i had wrong code please
Punteggio 0
1 Commento:
da
This reset does not work on my W1012v. Say what u want. It dont work.
Punteggio 0
I agree! It did not work on my RCA Galileo Pro tablet either. So far, RCA hasn’t been much help either!
Punteggio 0
How can I Remove RCA Setting Lock, Or what is the cause for RCA Tablet to go in setting Lock……
Punteggio 0
1 Commento:
Please Help my remove my Rca Tablet Setting Lock
da
Aggiungi la tua risposta
Breland Destiny sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 4,588
