Salta al contenuto principale
Can I replace a failed logic board A1211 with A1226?
My current A1211 logic board needs to be replaced but I want to move to 64 bit ROM in order to install the current release of OSX. Can I install an A1226, which appears to match in all significant respects except for the processor and video card.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
It would be a very large undertaking and I'm not sure it would buy you that much if it worked. Remember this series has a known issue with the GPU so you can't push it that hard without it failing.
While the A1226 is able to run newer OS's than the A1211 the performance is not that good and many apps today need much more memory than the limit of 6 GB you have here. I think you can do better looking for a newer used system than trying to get this system working again
Just to be clear here OS-X El Capitan 10.11.x is the newest you can run.
Punteggio 1
Parti e strumenti correlati
Acquista tutti
Aggiungi la tua risposta
mountainhighm sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 176
