Salta al contenuto principale
The Shark Rocket HV301 is the second installment of vacuums in the 300 series. It is a two-in-one vacuum that comes with several attachments, making it capable of cleaning on different surfaces. Its sleek and lightweight design make it easy to maneuver around any household.
What do I do if the device won’t turn on?
My device is plugged in but will not turn on; what do I do?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi, if your device isn’t turning on you should try a different electrical socket to see if it could be an electrical problem. If it still doesn’t turn on, try waiting 30 minutes to see if the vacuum has just overheated. If you’re still having trouble, it is likely that your power cord has malfunctioned, so you may need to replace it.
Punteggio 0
Aggiungi la tua risposta
Shelby Baccala sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 23
Tutti i Tempi: 550
