Salta al contenuto principale
Rectangular Form Factor / 16 GB capacity / Announced September 12th, 2012
What adhesive to use when replace screen
what adhesive to use when replacing screen
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
First of all, you sir, are insane for even touching something this microscopic.
Second off, I would use a VERY small amount of plain old super glue, crazy glue, or clear epoxy resin, around the edges of the LCD frame (apply with a toothpick etc)
Or I would use Optically Clear Adhesive (OCA) glue on the screen to bond it to the digitizer.
OCA glue is a UV activated glue that's specifically meant fo bonding LCD screens to digitizers you can get it off eBay for as little as 5$
Personally I'd go with the super glue.
Hope this was helpful! Good luck!
Punteggio 0
Parti & Attrezzi Popolari
Acquista tutti
Aggiungi la tua risposta
samwall sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 726
