Salta al contenuto principale
6th generation Android smartphone designed by Google and manufactured by LG. Model LG-H790. Released October 2015.
Microphone not working in call
My Microphone won't work during a call unless I activate loudspeaker mode.
I dropped it in wet grass recently which may be the cause
Mic works on a voice recorder app or while taking videos.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Back up your data and factory reset your phone, if that doesn't fix the issue I'd say you're looking at a faulty Mic. You'll find the part on most site like ebay and even if you ordered it directly from LG. You'll also find disassembly guides for your phone here on ifixit.
Punteggio 0
1 Commento:
I have same problem. Are your phone fixed? If fixed can you guide me how to settle that problem
da
Parti e strumenti correlati
Acquista tutti
I fixed my issue by cleaning out the microphone hole with a needle. The hole was filled with grunt, once removed the microphone worked.
Be careful not to stick the needle to far in.
Punteggio 0
Aggiungi la tua risposta
Ben Lyons sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 3,187
