I cannot switch laptop on. Power button blinking
OnOff button blinking. Cannot turn ZenBook UX305 unit on
Questa è una buona domanda?
Shlomo Shamir try the following and see if that helps.
- Do a hard reset, unplug the AC adapter from the laptop and press and hold the power button for 30 seconds.
-Test your AC adapter with a multi meter if it's supplying enough voltage required by yourZenbook to power it on.
If you do want to take it apart, this link will show you how.
Great, important info. Thank you very much. Harmony is restored :-)
Bluestick. I tried in mine, and laptop is reset holding power button for 15 seconds. BUT, why is this happening, do you know? Because it happen to me very often, like 1 time a week, and I loose all the things I had in my desktop. I would like to solve the problem of not having this blinking anymore.
Thanks.
Very helpful. Thank you!
Thanks so much, this worked! Any idea what causes this fault?
It worked for my Asus zephryus rog too. Thanks so much
i am sure all you need to do is pull the battery ... hold the power button for about 20 - 30 seconds ... plug the battery back in, and hey presto !!! your laptop should be functional again :)
oh god thank you so much this worked. i held the power button for around 30 seconds as you said the i plugged it back to charge and it came on. thought i wouldve had to buy a new laptop my mom said she wiped the keyboard it was sticky and it ended up blank and in the state it was in i dont see any keys tha couldve send it into that state .
Omfg it worked, thank you!!
Held power button for 30 seconds. Started ok. Thanks
Thank you so much 🥰 This is very helpful ❣️
Thank you very much, saved my sanity
Hello all, it looks like that my issue with the laptop was the display cable and the only way to fix it is to replace the display cable or display it with the cable.
—— My issue ——
- Power on -> doesn’t show any picture on the screen but looks like working, in order to start again you should hold power for ~10 sec. to get the fan spin.
- Power on -> display picture on the screen but only on the special position of the display - after a few min just freeze, in order to start again you should hold power for ~10 sec. to get the fan spin.
My laptop start having issue after 23 months. After sent to the Asus workshop to check and they said can't find any faulty parts. On 24 months, the laptop is not able to turn on without 8 hours rest.
I have done the hard reset but the same problem came back after 1 week.
Symptoms:
- Both power and Caps led on.
- Must disconnect the external keyboard and mouse or otherwise it won't be able turn on even after 8 hours rest.
- Battery was growing in size after 24 months. Due to the battery growing, it affects the keyboard (the center of the keyboard has a small hill) and later not able to close the screen. So, I removed the battery from the laptop because I scared that the battery explode.
I recommended this laptop to most of my co-workers and they bought it even though it's quite expensive. I just worried that one day they will condemn my recommendation.
If this problem can't be fix, most likely we will switch to other brand.
Sir, if your battery is growing and affecting the keyboard you need to stop using your laptop immediately and remove the battery or it may explode or start leaking and damage the motherboard(s). A cell in your battery is defective and causes the battery to swell.
Thanks for your advice. The laptop is not able to boot up any more. It's time for me to get a new one. :)
Thank you all... 20 second trick worked
Same, press the power button for 20 sec
@honwanlau You don't have to buy an new one. Make a new question on Ifixit and ping me @diode_cool in the question
Please go to bios and set default setup, restart and issues will be solved
For people having this sleep issue with old (for 2025 :) ) asus laptops. I've managed to fix it with changing sleep mode to s3 (from "modern" s0 which puts laptop to sleep without beeing able to awake).
Instructions for example: https://www.makeuseof.com/windows-disabl...
My issue was that asus goes to sleep and then does not wake up. Only "long press" helps to reset it.
Ultime 24 Ore: 69
Ultimi 7 Giorni: 490
Ultimi 30 Giorni: 1,923
Tutti i Tempi: 315,956
36 Commenti
can you upload a pic of the laptop as I'm not how accessible the battery is ...
da Reboot Gozo
I am getting the same problem. My White Power light is blinking on the battery signal and doesn't open.
da Canon
I did at your answers suggested and now my screen is still blank and the power light and airplane light are on constant - if anyone could help, that would be great.
da NiamhN
Me too ky power ligth is blinking but i cant on my Asus Notebook...
da Judy Christine Angell
hold the power button in for 20 sec or so and it will turn on. have the same issue sometimes but don't know what causes it
da adrianc.grigoras
Mostra altri 31 commenti
