Salta al contenuto principale
Un tablet rilasciato nel settembre 2015 da Amazon, dotato di un display touch screen da 7 pollici. Numero di modello: SV98LN
Where do I get a new battery?
I have a Kindle Fire 7 (SV98LN) fifth generation, opened it up and found that it has a battery with model MC-308594. I'm having the issue where it shuts off when between 74% and 94% of power. I want to get a replacement but only found two on EBay, and none on Amazon. I can find batteries for almost any other device. So where do I get a replacement battery? Or is it that Amazon would rather I just buy a new Kindle?
Questa è una buona domanda?
Punteggio 3
5 Commenti
Well, I got my new battery. It installed much easier than when I took the old one out. For future reference, is there a way to release the battery easier? That glue/tape was the hardest part for me.
da
Where did you get a new battery?
da
I got mine on eBay. Just do a search for "sv98ln battery"
da
Double check the connectors on the ebay batteries. I just got mine and it had a 7 wire connector vs. the OEM 6 wire connector. Needless to say, the new battery doesn't fit even though the seller claimed it did.
da
Regarding battery removal, I just saw a video where a hair dryer was used on the back cover before removing it. (Maybe 20-30 seconds)
da
Aggiungi un commento
3 Risposte
Soluzione prescelta
I have found a website that has the MC-308594 battery for the kindle fire 5th gen for $14.25 The website is BIGUPGADGETS.com . The batteries you get on eBay are used , this one is new with a 1 year warranty.
Punteggio 1
2 Commenti:
Do a search on eBay for "sv98ln battery" and you will find many choices now. There must be a bigger demand as these Kindled get older. ..
da
Bigupgadgets no longer sells this battery. The battery clerck does though for 19.95
da
Risposta più utile
Here's how to replace it:
Kindle Fire HDX 7" Repair
Here's a battery:
http://www.batteryclerk.com/Amazon-Kindl...
Punteggio 2
4 Commenti:
@mayer, wrong link :-) SV98LN would be this one
da
Sorry, but this is the same issue I had researching this in the first place. I don't have an HDX. I've already popped my Kindle open to get the model number of the battery itself...
da
Of course as I am typing my response on my Kindle, the prior link is sent... But no mention of where to get one. I'm having a hard time finding new ones.
da
Oops - prior should be proper. Can I blame that on auto-spellcheck?
da
jayeyeemm take a look on here and see if that will work. Call those places dfor more information if needed. Always good to talk to someone. Or is it that Amazon would rather I just buy a new Kindle? Absolutely yes. That is the reason for existence of ifixit......Here are the directions on how to change it.
Punteggio 1
2 Commenti:
Wow... That looks right, but $54? I may as well get a new Kindle at that price, which is what they want me to do anyway. I was only able to find 2 used ones on eBay around $20 each.
da
I hear you on the price. I am going to continue to check other sources as well and will update my answer as I find a cheaper solution.
da
Aggiungi la tua risposta
Jim15227 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 31
Tutti i Tempi: 6,292
