Salta al contenuto principale
The Toshiba Satellite C655D-S5084 is a mid-cost laptop that is a part of the Toshiba Satellite C650 series. The C655D-S5084 is a customized version of the base model.
10 Domande Visualizza tutte
Turns on and off when booting
I scored a Laptop for nothing but it has a problem where it will not boot at all.
I am told at some stage someone replaced the RAM but and instantly stopped working.
When you try to turn it on it has power and attempts to boot but the screen stays black and after about 10 seconds it turns off again?
I have reinstalled original 4GB of RAM and removed the HDD to see if it would take me to the BIOS, but nothing seems to work.
Any suggestions would be helpful thanks.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Is there multiple slots to install the Memory? Could be that the slot you are using is bad. That or the memory isn't currently seated all the way in the slot.
Punteggio 0
Aggiungi la tua risposta
Harley Greaves sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 105
