Salta al contenuto principale
Also known as NX.MH1AA.011. This 15.6" LED touch screen laptop was released in June 2014.
Laptop Key (W) is not working properly
Hello.
I'm using Acer Aspire E1-510 laptop and my "W" key started "blocking and freezing" 2 days ago. I don't know why is that happeing but i thought it was because of the dust,so i vacuumed and it didnt help. I also removed the key and tried a "deep" dust clean,but it didn't work...
Sometimes it works normally but sometimes i have to push it about 20 times to write a single "W".
Sorry for my bad English :)
Cheers!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Usually this is because of debris or dust on the connector for the keyboard. My laptop had this problem.
I took the laptop apart until I could get to the keyboard connector. I removed the keyboard and cleaned the connector by taking an eraser and "erasing" all the dust off. The pins were a lot more shiny and the keyboard worked perfectly after that. I hope this helps.
It could also be helpful if you searched "Acer Aspire E1-510 keyboard replacement" so you can see how to properly remove it.
-Jono
Punteggio 1
Aggiungi la tua risposta
Dino Covic sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 13
Tutti i Tempi: 537
