Salta al contenuto principale
The Alcatel One Touch Idol 3 features a 5.5-inch, 1080 x 1920 display powered by a 1.5 GHz processor. Released in June 2015. Models 6045Y, 6045K, 6045O, 6045I.
Why is my power button not functioning
my phones power button wont let me turn my phone on and I don't know what to do
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hold down the power button and Volume down simultaneously. Hold for about three seconds then release both. You will not see anything, but now try the power button. Phone should power on. Also, go into Settings>Gestures>Double Tap and enable that feature. Doubling tapping the screen avoids the physical power button just in case problem pops up again. Good luck.
Punteggio 3
2 Commenti:
HE said his power button dont work how would this help lmaooo
da
It does help because you can turn on/off display that way without using the power button. For initially turning on (in order to change the settings), you can connect it to power.
da
Parti e strumenti correlati
My phone is charging but won’t turn on what do or can I do?
Punteggio 0
Aggiungi la tua risposta
Atidadeoluwa Awodele sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 8,799
