Salta al contenuto principale
Guide di riparazione, supporto e informazioni sulla risoluzione dei problemi per i modelli MacBook Air con schermo da 13"
Display connection is covered in tape
The display cable is covered all around with a yellow transparent tape. It is not attached to the socket. When i peeled the tape back the cable came with it. Could this be the source of my display problem. And no this has never been tampered with. I do not understand how it worked before. Should i connect and try before i proceed with display replacement. The mac was dropped and display went out.
Questa è una buona domanda?
Punteggio 0
2 Commenti
Can you give us your exact model info. If you don't know you can check it here using your systems S/N: EveryMac
da
That machine has been worked on. Apple did not do that.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
ok I decided to stop disassembly at that point and plugged in the cable. I then reassemble the air and booted up to check the screen.
all I got was some lines across the screen and then it went out. At that point I decided to replace the screen I received from Ifixit and rebooted the system again and voila! there was my computer. I did make a boo boo though I damaged the blower connection and had to order a new one :(. I was surprised the system booted up to show me the screen worked. I had to shut off before I overheated the cpu. Thanks for the response guys. Is it usually that hard to get that blower connection to connect? Yep I unlock the clip.
Punteggio 0
Aggiungi la tua risposta
asini1 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 96
