Salta al contenuto principale
Released November 1998, identified by model number HKT-3020.
Controller Port 1 doesent work
Hey Everyone,
I got a Dreamcast from Ebay, but the Controllerport A/1 doesent work. All the other, B/C/D works perfectly.
I hope you can help me
Questa è una buona domanda?
Punteggio 0
3 Commenti
Do you know how to solder? If you don't, your best bet will be to purchase a replacement controller board off ebay and simply swap out the part.
da
yes i can solder, but why?
i read a lot of the problem on the internet, but that is always all controller prots, not only one. so i think the problme withe the fuse coulnd't be
da
The reason I ask is that controller port board on the Dreamcast is among one of the more friendly parts for soldering, since all the components are through-hole. I would do a continuity test on the fuse, just to rule it out as a problem.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
This guide would be the easiest, if you don't want to solder it
Sega Dreamcast Controller Port Replacement
This guide would use a little more work, but you could individually change out one controller port
Also found this on eBay
https://www.google.com/aclk?sa=L&ai=DChc...
Punteggio 2
Parti e strumenti correlati
Aggiungi la tua risposta
thunderblrd sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,503
