Can't fully insert sim tray
Hello
I have a nexus 5 but the sim tray doesn't fully fit in.
The tray stops a bit before it is fully in.
Does anyone know what could cause this problem?
Thanks
Questa è una buona domanda?
Ottieni un rapido accesso alle guide, ai componenti e alle risposte per i tuoi dispositivi
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 598
Was this a cut sim card like from normal sim to micro sim? Because if they are not cut properly then issues like this can occur.
This may be a dumb question but make sure you're not inserting the tray upside down.
da Ben
I'm only using the tray, so no sim and it doesn't click in place.
I have tried upside down so that's not it
da Lukas Guy
Are you certain the back is snapped on all the way?
da David Spalding
Something else you might try: get an old SIM and insert the tray with it. The tray may need the added rigidity of a SIM card to slide in properly.
da David Spalding
