Salta al contenuto principale
The WorkCentre 7755 is a color multifunction printer.
problem with xerographic system
How we rectify problem with xerographic system
Questa è una buona domanda?
Punteggio 4
4 Commenti
how we rectify problem with xerographic system
da
Plz help me xerographic fault
da
Please help me xerographic fault Xerox 5755
da
xerox workcentre 7835 "altboot" full driver
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
Re: Xerographic Fault
  1. Reply With Quote
  2. 06-28-2016#4
  1. Xerox 5755 geographic failt and paper jam left door
Sent from my Che1-L04 using Tapatalk
  1. Reply With Quote
  2. 10-17-2016#5
  3. andywong90
  1. Hello,try chg the cleaning motor for main charge.this motor located at rear main motor
  1. Reply With Quote
  2. 11-13-2016#6
  3. Manuas
  4. TechnicianJoin DateNov 2016LocationMaui,HawaiiPosts20Rep Power5
  1. Try another drum. Clean transfer unit. Remove ALL trays and BE SURE NO paper or debris behind trays and up in top areas. log into diags mode and clear codes then let it fail then go back in and look at code. Trace code and you will find problem and fix.
  1. Reply With Quote
  2. 11-14-2016#7
  3. Exok
  4. Field Supervisor500+ Posts     Join DateJun 2011LocationEdison, NJPosts731Rep Power28
  1. Reporting your fault codes would be a help in troubleshooting. For example, if the xerographic faults are occurring with 9-060 faults, you could have a faulty High Voltage Power Supply or poor connection on the board.
  1. Reply With Quote
  2. 11-27-2017#8
  3. aims
  4. Junior MemberJoin DateNov 2017LocationTAMILNADUPosts1Rep Power0
  1. Originally Posted by Exok
  2. Reporting your fault codes would be a help in troubleshooting. For example, if the xerographic faults are occurring with 9-060 faults, you could have a faulty High Voltage Power Supply or poor connection on the board.
sir i have this issue then i changed 4b unit (blue handle unit) and also i have installed stabilizer but stll now i have these issue with error code 9-560 what to do please help me
  1. Reply With Quote
  2. 02-23-2018#9
  3. THKUVESH
  4. Junior MemberJoin DateFeb 2018LocationVERAVAL GUJRATPosts1Rep Power0
  1. Xerox 5755 foult code :- 03-480 power supply foult
03-777 sip recovered form an uncontrolled power loss
how to solve this problem dear frds.......
May i change new power supply unit but the action is continued...........same foult
and service full machine.......at one by one all part.....
And i replace the power supply change with other machine that are work perfect and complete
Punteggio 1
Parti e strumenti correlati
Drum Chips problem,removed or replaced
Punteggio 0
Punteggio 0
Aggiungi la tua risposta
Dharmendra Pandey sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 63
Tutti i Tempi: 6,429
