Salta al contenuto principale
L'aggiornamento di Marzo 2015 della linea 13" dei Macbook Pro con Retina Display (modello A1502) adotta processori Intel Core i5 ed i7 di quinta generazione, introduce inoltre il trackpad Force Touch.
2.0 Gbps SSD from 15" model
Is the faster 2.0 Gbps SSD (versus 1.6 Gbps) from the 2015 15" MBP compatible with the 13" MBP? If they are I would like to retrofit my 13" with the faster drive from the 15".
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Sadly, no
The newer MacBook Pro systems use a Proprietary interface based on PCIe: PCIe 2.0 x 4 lane. The previous version of MacBook Pro's use a PCIe 2.0 x 2 lane version.
Punteggio 2
4 Commenti:
Thank you for your answer but I did not mean an older Macbook. I meant taking the SSD card from a 15 MBP and putting it into a 13" MBP, both being of 2015 vintage. Apple lists the 15 model as 2 gbps and the 13 at 1.6 gbps. Im wondering if they are interchangeable, same year Macbooks Pros.
da
Both are listed as PCIe 2.0 x 4 lane. Sorry to say I haven't tried swapping them around.
da
I wonder why then the slower speed on the 13" model....
da
Different suppliers I would guess
da
Aggiungi la tua risposta
Maxim sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 129
