Salta al contenuto principale
iPad Air Wi-Fi + Cellular, model no. A1475. Available in Space Gray or Silver, with 16/32/64/128 GB configurations.
Domanda Chiusa
Running erratic since iOS update from 9.0
Since update from 9.0 iPad has been running erratic. Keyboard double types, or not at all sometimes. Opens previously viewed Windows, types like someone has taken control. Erratic is saying it nicely, it's like possessed;all updates only worsened the issues! It took an hour just to post dis!!!! Help"??????????
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Go to Apple website...or connect to iTunes ..see if they have any new updates now...also you can back up your info...with iTunes..then do a factory reset...in the settings on your phone..reset it ..and if u want all the stuff back on it...connect to iTunes and it will put everything back on the iPhone...should be good to go after that....good luck
Punteggio 1
4 Commenti:
I did a factory reset, including erasing all previous content and settings, prior to reset. However, it did nothing to correct the issues. I believed the reset would return settings, including iOS to 9.0, but it did not! It was this updates, after iOS 9.0 that put these bugs and subsequent updates only worsened it!!!
da
contact Apple or go online search to see if others have same issues...good luck
da
Thank you very much for the assist. There are others with similar issues, "ghost" or something to that effect is what they are calling it. But I contacted Apple support & I can take it in to a support site and have it "factory restored."
Aloha LeonardF
da
Cool glad to hear ..anytime my friend..welcome
da
Parti & Attrezzi Popolari
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 108
